I am in the process of assembling 3 rear gate cranks and have hit a snag. The black OEM handle I found trapped / entombed under the seat of Little Red when I was disassembling it. With the radio rack in place from the factory the seat could never be folded forward so I assume it was entombed before it left the factory.
View attachment 928223 It has a bit of rub rash on it and I used steel wool and 400 grit sand paper to clean and smooth the area. I will touch it up with a spray of flat black. Since I don’t have anymore lock cylinders, springs and pawls I ordered a set on line my MOT My Old Truck. Catchy.
View attachment 928224 View attachment 928225 View attachment 928233 I have yet to get it to assemble after spending an hour and a half on it. I suspect the spring has to much tension. I went and dug out another crank I had in my parts bin and was surprised to find a key that fit the cylinder and activated the pawl in and out. Fat chance that is the correct coded key but it works and I am happy for that. That was parted from a gate I bought at a Youpullit that had no key. It is an OEM GM part. I am going to add a clutch, paint it and use it on my last M1009 I build.
View attachment 928227 View attachment 928228 View attachment 928229 I keep keys and many other things that annoy others. But when people need things the come see me. Needful Things.
View attachment 928230 Strange the ignition key fits from an 84 Chevette I bought new. But the CUCV key will not go in the cylinder. I don’t like the old school octagon GM keys that come with the MOT kit but I was thinking of taking them to a lock smith and getting the cylinder coded for the CUCV. I know some one out there had a bad crank or lock cylinder they are never going to use.
View attachment 928231 It locks and unlocks good enough.
View attachment 928232 I other same year style keys and they don’t work. What are the chances of that?
