Ambulance rear doors
shorad93
25
Pembroke Pines, FL
Any chance I can get some leads on getting the two rear doors and a step for newly acquired m997-a2. Thank You all in advance!
Hello,
I just purchased a M997 2 weeks ago with the same issue, no rear doors. However, I was able to acquire 2 right side doors through ebay of which I deconstructed one of them and then reverse engineered a left side door using the same type aluminum, 1/4" PVC sheet, 3/4" plywood (Treated) and sandwiched together with marine grade adhesive and small bolts throughout. Total investment for one door is roughly $350. The door is much stronger than the original to which I bolted a spare tire carrier. This week I'll be building a right side door using same technique.
Mogman
8,985
Papalote, TX
Nice work, sounds like you need to start producing doors.
I do have concerns about the tire, they weigh around 200lb, IMHO the door hinges themselves will not support that much weight over a long period.
shorad93
25
Pembroke Pines, FL
Aaahhhh! I'm ahead of you. lol. I actually purchased another hinge that will go in between the other two to give it more strength. My plan calls for adding a small crane on the roof, possible electrically operated to lift and lower the spare. I'll keep you guys posted as I progress along.
Pafcllc
9
Jacksonville, FL
Yeah, I second that, very neat looking door. Did you reuse Kevlar lining? I have already bought original doors. What are your plans re steps (assuming they were removed too)?
TOBASH
3,246
Brooklyn, NY
Hello,
Amazing work, and to all the NaySayers, treated plywood kicks ass for applications like this.
Great post about a common problem!!!
shorad93
25
Pembroke Pines, FL
My M997 didn't have any Kevlar lining. The 2 right side doors I purchased were older. They both had an Interesting stencil saying "warning, these doors not to be used in combat". Once I disected the 1st door, I understood why. Very flimsy design with aluminum bracing and hard insulation sections to fill the voids.
For the steps, I just picked up an RV step that I may modify to include making the cover. This step looks heavy duty and I think with some mods, I can make it work. Standby for pix later.
spankybear
848
WA
Hello,
Very nice!
spankybear
848
WA
I have an ambulance and Im just building my own. Its a PITA but slowly coming together. Plus Im making them semi bullet resistant
I built mine and it was easier than I thought. I did look at Kevilar panels but didn't want to spend the $$$$ to build with. Other than being "tacticool" I don't foresee a need.
Flateeg
Grand Island, Nebraska
Where did you get the latches? Im building mine out of 500 steal with steal panels I really dont know why I am going over the top. I think its to teach my twin boys to weld.
spankybear
848
WA
What I did was get the parts TM and then get the part numbers. I search the part numbers and found them on line. One side came from the Hummer Parts Guy and the other side from Equipment Parts Sales. I fond the handles at army surplus warehouse. Part of the game/fun is finding parts. It's a treasure hunt. The only issue with surplus is it will dry up. It's an on going hunt. Also i am cheap so I try to find the best price. Not always easy. Hope this helps.
To convert the part numbers to a NSN I use part target. Sometime the same part will have multiple part numbers. Take the right latch. The TM calls out 12341711-1. Take that number and use part target to find the NSN of 5342-01-264-6533. Scroll down are you also find the other part numbers like 12341238 and 5597989. Search the numbers and sometime you will get lucky...
I think HPG is out of stock. EPS has one side but has gone up in price. Army Surplus Warehouse didn't have a part number listed but the picture looked to be right. I went ahead and got 2 and they are correct. Here's a link to the handles https://armysurpluswarehouse.com/military-issue-humvee-rear-outer-door-handle/
Part target also has the manufactures on some items. You can also search on the manufactures and go that route. Like I said this is a treasure hunt. I use the above and map out to the X.... and sometime the treasure has been found by someone else...
Enjoy
Flateeg
Enjoy
Thanks brothers. It is true. I like finding the parts or building it my way. Its a big toy. I could paint it pink. (I wont) but its as much as you want to do. I just ordered the steel door kit. When the zombies come I will be ready Lol
