- 458
- 934
- 93
- OR
If you just use your bottle jack and lift it up just a minimum to where the the wheel is loose on the studs, you can just walk the wheel right off and roll it over and lean it up against the truck you won't need all that cherry picker business
The Jack stands you're trying to use are way too tall in my opinion, the bottle jack should hold it just fine while you do what you need to do don't stick your hands underneath it
If you don't like that or have safety concerns I'm sure you got a stump or some blocks of wood or something around there you can shove under it
