thompsoncustom
- 115
- 43
- iowa
thanks I'll start it and check. only thing changed inside the box was the original trigger wire was cut off and capped/tied up and I added a new wire from the battery side of the solenoid to a switch and back to the trigger on the solenoid. should I have left the original wire took the the trigger of the solenoid also? didn't know if back feeding would be a problem. and I can't see how this would change anything.Check and make sure your heater blower works, it is on the same relay that excites the alternator, I would suspect you are not getting 24V to the IGN terminl on the regulator since rebuilding the PCB box.
