electric winch on deuce
rustystud
3,242
Woodinville, Washington
you can control the heat with snatch blocks by reducing the load and draw off the batteries, if the 18k warn works on a mrap it'll work on my much lighter deuce, only drawback i could find when winch swapping was it "only" has 75' of cable that could reduce the amount of real estate for snatch blocks if a close anchor is not handy, so when rigged up ill have a couple lengths of cable along
I have four 25ft lengths of 3/8" Grade 70 chain I keep in a bucket. Each length has it's own hooks installed so I get gang them together for another 100ft if needed. I also have three snatch blocks so I can get down and dirty. I suppose I should also carry some 100ft of cable with ends on too. That way they can help with the snatch blocks.
Aussie Bloke
404
Lost, out bush in OZ
G'day everyone,....
I would have thought you already would have the cable to extend you winch cable, I would think its lighter than chain?
Oh and have you tried how long your electric winch will run on just the batterys alone under load?
Aussie.
rustystud
3,242
G'day everyone,....
Aussie.
I like having the chain as it is stronger then the cable and it can go around rocks and such without getting damaged. I have used the winch with the engine off just to see. I never let it go till the batteries ran out of charge though. Basically with my two batteries at full charge I could get myself out of a pretty nasty hole. I have about 10 full minutes of use. Maybe a little more. Since you never just hold it down for that long I have plenty of spare time available. During the average "extraction" you only use the winch for a few minutes total. Most of the time is set-up, pull a little and then reset again. The longest time I ever used a winch was trying to move a 5 ton dump truck with four flat tires with a 8,000 Ibs WARN winch across a flooded field. That took four hours with two snatch blocks and 50ft of chain ! In the Marines I could extract a stuck fully loaded 5 ton truck in less then a hour with the 5 ton wrecker. If I had the M88 tank retriever it would be less ! Of course I would also have the help of a fully trained crew.
speedfellon
grass valley ca
View attachment 727495 This M35A2 with an electric winch belongs to Steel Soldier speedfellon. Just took this pic last week in Petaluma. Not sure who the manufacturer is or how well it works. But maybe he'll chip in with the details.
18K Warn Industrial. Works great only 65' of cable. but I carry a 20' cable off a tank and a snatch block for added length. Usually just pull trees around property. Not paying attention once I pulled cable completely off winch. my other 8K warn has 150' cable. wont make that mistake again.
cavtrooper78
211
Oklahoma
I know this thread is old, but I’ve been looking for a milsurp winch for the deuce and they seem really hard to find.
marchplumber
3,110
Peoria, Illinois
Suggest a "parts wanted" add............
also could go to larger suppliers, they have "ads" here on site, they could help ya..........shipping might be a bit expensive..........
98G has a way of finding things too, and in same quadrant of the country...........
WELCOME Aboard and "First Team!"
cavtrooper78
211
Oklahoma
Thanks for the info! If you ain’t CAV…😏
KN6KXR
640
Felton, CA
I have a couple "Force Protection" MRAP winch kits brand new in crates. I had to buy a lot of three to get one for my deuce. It'll yank the deuce all over no problem. Usually I'm in the cab with the engine throttled up on the brakes with the remote. They are pretty strong winches: 24V, submersible, 18k#. Boyce will sell you the frame extensions and mounting setup they make them with their custom trucks. The kits come with a McKissick 10 ton snatch block it's heavy... Anyways they weren't cheap after tax and auction fees they cost me $2500 each. So that's what I'd want for them. I'm not going to find the submersible Warn 18k with cable, roller fairlead, snatch block and wiring hardware for that price anyplace so I'll hang onto them for another project if nobody buys one. They may still be auctioning them do a search on GovPlanet sometimes it's a slow day and you can get a better deal than I did. They are pretty cool they come with all the source docs and proof test papers.
cavtrooper78
211
Oklahoma
I appreciate your response, but that’s out of my price range right now sir.
