I finished the driver's side door with a freshly painted handle and new gaskets. The white specks are paper towel residue.
I was looking thru my selection of right windows and came across some with rough sashes.
I chose the best one I had and installed it in the door without the weather strip run.
That was always the easiest way for me. Getting the 3 roller guides into the tracks is much easier this way. With back track not installed that gives you a lot of wiggle room with the glass and new run seal.
Like most CUCV's this truck at one time had a loose window regulator and waddled the holes out at the shaft and a few of the other bolt holes. I used a track bolt with the larger washer. That is normally anchoring down an adjustment point in the door or rear gate glass tracks.
This bolt and J nut is located below the wing vent window. It is very important that it be in place and tightened. Not so tight that it dents the outer door skin. But tight. It is a 5/16" drive head and you can reach in an tighten till it almost touches the outer door skin with the point. I have used an air gun once and guess what happened on a new paint job. All this reassembly I am doing with a 1/4" rachet and sockets. No race and it makes things look better and you can relax and pay attention to details. There is a J nut clipped into the inner part of the door. Mine fell off during the wing vent installation and I spent an hour getting it back in place. Part of the half fast work process. I am in the process of loading more pictures. Take Care. Thank you for the support.
