Seems like this is turning into a build thread.
cucvrus
10,427
Jonestown Pennsylvania
I seen 2 CUCV's that had a slave cable port on the rear bumper. One was an M1009 and the other was a Pickup. It was not OEM but none the less they were there. Power points for whatever. Are the cables you have long enough to reach a certain point front or rear. Possibly a 24-volt winch. Heaven knows 40 years later.
CARC686
484
Las Cruces, New Mexico
The wires ended right at the grommet where the 24v radio cables pass through the floor pan as if somebody just snipped them off. It did cross my mind that the license plate recess on my bumper could be a great place for a 24v winch, but then winches are shockingly expensive, so probably not.
CARC686
484
Let there be light. Thank you to @WWRD99 for the NPS adjustment procedure and thank you to @cucvrus for the bulbs.
Anybody know the pinout on these? Goal is to power the flood light with the trailer reverse circuit.
AI doesn't know what it's talking about most of the time, so as a rule, I tend not to listen to it, but it did just tell me that the M1009 trailer connection has no reverse light provision, and given four wires, that covers ground, run, turn, and brake. It's probably true. Bummer.
deank
374
Florida
You could tap in to the reverse light on the left or right side or at the connector on the frame.
CARC686
484
Was concerned with electrical load, but the harness was designed for a nominal 26 watt incandescent bulb, which is roughly equivalent to the draw of the LED 1156 and the LED floodlight combined. The size, weight, and lumens of the floodlamp were giving me worries of letting the magic smoke out for no reason. Thank you, sir.
WWRD99
1,712
York Pa
Glad the reverse lights work now! It's odd the diagram you posted shows 4 wires when there's 6 with both plugs on the truck. Throw it in reverse and see if one of the wires gets hot...I'd back probe that since I think the harness grounds itself with one of those wires. If not I'd run another wire from the switch out...maybe relay it...but that depends on how much light amp load your putting on it.
CARC686
484
Yeah, there are six wires in the plugs, but the diagram only shows four, which led me to presume it was a universal part across multiple platforms and the other two wires on the CUCV aren't connected to anything. I don't know that. Just assume it based upon the TM. I checked every wire against every other wire for voltage KOEO in reverse last night and got nothing.
Mathed it out to about 19 watts at an amp and a half for one LED 1156 with one Badlands floodlamp at 12v. This is actually less than a single incandescent 1156. The manual for the floodlamp states that they're 12/24v, which may be of interest to people here.
deank
374
Florida
If you run a separate power line for the led light, you could use the reverse light positive to activate a relay for the led light. Withe relay under the hood or in the cab.
cucvrus
10,427
In the 6 wires at the rear trailer plug outlet you have stand service lamps.
Right turn/stop
Left turn/stop
Park lamps
Ground wire
Black out trailer wiring
Amber cat eye driving light 4 amber slits per side
Red stop lamp 1 red light in center of the Amber slits with the park lamps on. I hope that explains the 6 wires. No Back up in the trailer harness.
CARC686
484
I paid $20 a bottle for ATP AT-205 on eBay and received a package from Rock Auto. I looked it up on Rock Auto and was irritated to see I had been drop ship surcharged 33%. Just one more thing they hide in the menus so you can't find it.
Everywhere I park looks like a crime scene, so I figured this would be a harmless hail Mary before crawling into the grease pit for heavy lifting.
