CARC686
- 708
- 93
- New Mexico
That's actually where I bought mine....pretty hard to beat that price!If anybody wanted to try those 1/2" green belts, now is the time.
.Pricey, ain't it? I'll pull out the oxy ace and make one.
If your new aluminum radiator was produced exactly like mine, it will be approximately 1/4" shorter in height than the OEM radiator. I too used new Energy radiator bushings but still had to fabricate small neoprene rubber saddle spacers to sit on top of the aluminum mounting nubs to make everything bolt-down tight. Once you get that done, all other design attributes of the new radiator are identical to OEM. I haven't yet filled my new drivetrain with coolant but should get that done in the coming days. I'll post updates in my rebuild thread over in the CUCV Hotrod forum.Welp, the engine oil wanted out and it wasn't in a mood to negotiate. I poured three gallons in it just to make it back to the house, and every lingering stop light and malingering driver I got stuck behind was cause for profanity as hasn't been heard since I was enlisted. My truck doesn't have a name, but Jackson Pollock would be apt if you could see my driveway. Let's just say nothing under the truck is in danger of rusting. Figuring it would be a front or rear main, I wasn't worried because I already had spares on the shelf. One thing leads to another. The lower rad hose was well drenched, so I figured I'd best replace it, and since I'm doing one, might as well do both, which led to my discovering so much corrosion on the thermostat housing that I thought it was epoxy at first. Wired it down to find that it was just lumpy rot halfway through all around and I ought to replace it, which is how a seized bolt ended up snapped off in the crossover pipe. That's fixed and the new thermostat is in with the new housing. Everything's gasketed with red goop on both sides. I ordered that all aluminum radiator @Sharecropper is using and it showed up today looking like a giant piece of jewelry. I would hang it on the wall for decoration if it wasn't going in the truck. I hope it cools as good as it looks. When I got to eyeballing the OEM radiator, I noticed the bushings are long since rotted away, so I ordered some from Energy Suspension today. It's a good thing I'm not in a hurry, because I can't work like I used to and every time I glance at the truck, I have to order more parts. I've got 32 Rock Auto magnets on the fridge to the 1009's credit and if I keep it forever, which I might as well, I expect 32 more. There are bad seals all over the place and I'm going to keep finding them, breaking and replacing stuff along the way. I'll keep poking at it 30-60 minutes a day and by the time I'm ready to crank it, it'll pretty much be a shakedown cruise. It takes a lunatic to use this truck as a daily driver and god as my witness, I am that lunatic.
I've had the bushing kit for so long I can't remember which one I got. It's been years...........I'll see if I can't space them up with material cut from old radiator hose. That ought to last forever or near enough. Did you use the four row big block bushing kit? I assumed that would be the right one, since one wasn't specifically listed for the diesel.
