The Humvee takes off on its own like if someone flipped the "After Burner" switch.
MarkM
1,970
WOBURN. MA.
@MarkM maybe you'll like to try an ex-jet engine and see what it does (if it doesn't dry up your tiny fuel tank too quickly first) but..who knows!
A RATO unit would be better as it doesn't have to take time to spin up like a turbine. It won't last long but it would be one hell of a ride.
Mark
Dieselmeister
271
Flagstaff, Az
I had a bad cold advance thermostat, shorting out intermittently, causing the pump to advance. It accelerated the truck, but not like a rocket. Definitely a strange feeling though. Disconnect the cold advance wire on your pump, and see if the problem goes away.
MarkM
1,970
WOBURN. MA.
That's what I was thinking. Quick change out it That's it.
Mark
TOBASH
3,488
Brooklyn, NY
Diesel runaway is a serious consideration. Did you bypass EGR? Bad EGR? Oil entering intake air will combust like injected Diesel fuel. It is called a “runaway engine”.
You best ensure this is not occurring. It will blow up your engine and turning the ignition off will do nothing.
