24V Headlights
motormayhem
Tucson, AZ
Does anyone have part numbers for a set of 24V square sealed beam headlights that would drop in? One of my lights went out and I want to put that load over on the 24V system if I can. I already have a relay system installed so the headlight switch doesn't see the load from the headlights. So if I could find lights that fit it's just a matter of swapping the relay wires around.
Barrman
2,190
Giddings, Texas
I second that. Don’t make a wiring nightmare truck worse by making it more complicated. I have had the Trucklite LED units in one of my trucks 5 years now with excellent light and no issues or sun fading.
Barrman
2,190
Giddings, Texas
I wasn’t writing about the headlight relay set up. I have that on 3 of my trucks and think it is a worthy addition since my stock wiring hasn’t started smoking or melting.
I guess you could run 24 volts through the headlight side of the relays. But, why? 12 volts through lights are available just about anywhere and as already pointed out. LED versions are excellent for vision and long lasting.
It is your truck, so do as you wish.
MarkM
1,150
2,099
WOBURN. MA.
A lot of new LEDs will run from 10v to 30v without issue. Makes life a lot easier.
Mark
79Vette
173
Los Angeles/CA
12v sealed beams you can easily replace at any parts store with a relay harness is the way.
The relay harness is easy to put together, lots of write ups on the Internet how to do it. Or you can buy one for cheap. Either way it's definitely worth it
