That’s a shocking result. Really hard to believe actually. I did something similar but I used mlv instead of plywood. I’m still at 72 db idle and 87 db on the highway.I wanted to add some input after I finished doing my sound deadening and interior install this summer. I used these products everywhere there was metal inside the cabin as well as the top.
1st layer I used sound resonix butyl sheets after throughly cleaning.
2nd layer I used a siless foam
3rd layer I used a foil line sheet of plywood for the hatch and tunnel cover and for the floor was a horse stall mat
4th layer for the horse mat and plywood was an all weather boat carpet
Some other things I did to sound deaden was seam seal every crack, weld every hole, rhino line the outside wheel wells and floor boards as well as added sound mat under the hood.
the results were astounding with idles as low as 60db and highways in the 70-75db
I added a sound system and it sounds pretty much like a normal diesel truck from the inside.
I spent overall around $1000 for this result and it was well well worth it!
