- 2,873
- 9,395
- Alexandria, La
Ok, final update until I get home....
In a nutshell, I pulled the engine three times. The last time I pulled it, it was because the timing was WAY out..... I ended up finding the spiral gear for the oil pump was ganchy, so I pulled my OF one off, then it was various other issues until I pretty much stripped my OG block and rebuilt the donor block.
I learned how to time the engine from a factory setting, my kid learned how to use a torque wrench, how to set valve lash, fuel pump settings, distributor adjustment (rough AND fine), install and troubleshoot clutch, pressure plate, transmission, open the transmission and troubleshoot it, and a couple friends of mine have decided that @m715mike should retire his moniker and give it to me.....
Currently, the engine/transmission is back in the truck, I've started her and got her running, I'll be checking oil pressure and removing air from the cooling system and hopefully buttoning her up for good when I get home..... Enjoy more pics!
The shape of the spiral gear on the donor truck
Everyone who worked on her got to sign the fan
He's the Charlie Daniels of the torque wrench!
*NOT* the spousal approved method of testing thermostats...
Helping install the tranmission cover plate
Learning how difficult it is to install the #6 plug
