Huge mistake. I won a GP auction…. Cali FMTV Project “ ‘Merica”
NDT
6,957
Camp Wood/LC, TX
I thought your front driveshaft was bent as well? I would highly suggest you look into the u-joint puller tool, these caps can be stupid stuck in the yokes. Wasting hours pounding and cussing is not good use of your time out there.
serpico760
1,869
San Diego, CA
Definitely buy the u-joint tool. And pull both shafts. Just because it's not visibly bent doesn't mean it's still balanced. Some of these weren't well balanced when new.
I would say don't necessarily spend the money on the tool until you try it other ways. Mine came off actually stupid easy and I ended up not even really needing it. I had a standard two jaw puller that was a big one. I put two pieces of pipe around the ends and put those in the yoke holes, and pushed against the shaft and it actually came off easily. The tiger tool u-joint puller I bought turned out I didn't even need that either. Soak the pieces with something like liquid wrench give it some vibration and try it without the fancy tools first it might just work. I had way more difficulty getting the steering rod end off which took me several days of heating and pounding versus the u-joint and yoke which came out in a matter of minutes
TOBASH
3,720
Brooklyn, NY
All great suggestions and viewpoints.
Many thanks.
What about shock absorber alternatives?
GeneralDisorder
5,515
Portland, OR
Haven't encountered a bad shock yet that wasn't physically damaged. I'm sure it happens but I've not seen it. I would just source some used replacements. New shocks for our trucks has been a sticking point. There's nothing in the civilian space that really seems to be an easy drop in unless you go into the performance aftermarket and then you are talking $1000 to $1500 or more per wheel plus custom fitment - IE buy a lathe and make the adapters yourself.
TOBASH
3,720
Brooklyn, NY
My rig has a bent shock from a forking forklift at GovPlanet facility.
Same with drive shaft and tie rod
Ronmar
7,726
Port angeles wa
There is a discussion floating around here about shocks(search feature in LMTV section only), will have to look in my notes for the option I found most likely…
OEM Shocks:
20.94” to 33.26” 12.32” travel
5/8” top, 7/8” bottom (16mm top, 22MM bottom) bolts
the most likley off the shelf I found is a Monroe class7-8 truck shock.
Monroe 65456
20.25” to 32.88” 12.63” travel. So it is ~3/8” shorter overall length than the original(3/8 less full extension), but it has 5/16” more travel, so it is nearly 3/4 shorter when fully compressed… Not a huge difference from OEM…
It uses an L4 mount on each end(monroe documentation shows the specs for the L4 mount end). It is a rubber bushed round welded steel ring, so you will need adapter bushings and spacers to interface with the OEM hardware and mounts. I know of at least one person using them so far…
MatthewWBailey
1,746
Mesa Colorado
I’m not afraid to customize. Where can I find the replacement options?
This my effort at replacing mine, based on some older threads
