Bullet proof windshield
jake20
848
Illinois
ok, I need to reactivate this old post, I need to do something becuase my knock outs are starting to look bad and if peeling out layers gives me a a good look, again I need to do this. Am I understanding the process is to cut into the glass from the inside to be able to peel layers off?
It’s tedious and time consuming but can be done yes.
Best tool for the job seems to be an oscillating multi-tool. The inner side of the window has 2 layers of plastic anti-spall.
You’ll want to cut around the edges through the first layer, then heat gun it very carefully and begin to pry it. You’ll know you have too much heat if you start seeing bubbles. Also take care to not cut your heater wires.
Once you’ve peeled the first layer, cut the same depth into the 2nd layer, but don’t go too deep or you’ll start hitting the glass. Be even more careful peeling/heating this layer as you’ll be retaining the gel adhesive portion that remains stuck to the glass.
That final gel adhesive layer may now look cloudy, take a damp paper towel and just wipe it up, should be all clear.
Others may have had luck with peeling that last gel layer as well, but it’s incredibly stuck on. Best bet would be experimenting with some chemicals to dissolve it.
All in all, this is more of a temp solution in my eyes.
Greg841
97
WI
I got the last gel layer off by getting it started peeling up in a corner then grab it with a vise grip. Roll the vise grip back with a slow steady movement and peel up maybe a quarter inch, release, repeat. Just do little bits at a time. If you get greedy or try to rush it'll tear and you have to pick at it and start over. If you use heat it'll melt and tear. It'll take half an hour or more to do the whole thing but it's worth it. A little car polish cleaned up the remaining residue.
GMVguy
85
Texas
Did you happen to take any pics of the before/during/after?
alwayskaos
17
Lake Havasu City, Az.
Did you install the Ibis Tek windshields? I have no experience with these and I'm trying to gather the data to determine what I need. I do have a military contractor that has new heated windshields for these if your interested. Can I ask what the thickness of the Ibis Tek windshields is?
Greg841
97
WI
Of course I didn't, I was so excited it was working I never thought to take any pics :eek: I'll take some pictures this weekend though, I didn't use any black silicone on the inside edge to make it pretty so you can still see the layers that were cut out behind the frame.
163
24
San Antonio, TX
Well, I have installed them onto a standard M998 with modifications They will install on a standard frame. You can check out all my mods and detail on G503 here is the link where I post all me work. I use the G more than SS using the same user’s name.
https://forums.g503.com/viewtopic.php?t=315674
To answer your questions here are a few phote of the measurmentets:
Send me a message about your Post of a contractor, I'm interested than doing all the work. I have to many other projects Im working on if I can find a faster way, contact me.
