Bullet proof windshield
jake20
848
Illinois
ok, I need to reactivate this old post, I need to do something becuase my knock outs are starting to look bad and if peeling out layers gives me a a good look, again I need to do this. Am I understanding the process is to cut into the glass from the inside to be able to peel layers off?
It’s tedious and time consuming but can be done yes.
Best tool for the job seems to be an oscillating multi-tool. The inner side of the window has 2 layers of plastic anti-spall.
You’ll want to cut around the edges through the first layer, then heat gun it very carefully and begin to pry it. You’ll know you have too much heat if you start seeing bubbles. Also take care to not cut your heater wires.
Once you’ve peeled the first layer, cut the same depth into the 2nd layer, but don’t go too deep or you’ll start hitting the glass. Be even more careful peeling/heating this layer as you’ll be retaining the gel adhesive portion that remains stuck to the glass.
That final gel adhesive layer may now look cloudy, take a damp paper towel and just wipe it up, should be all clear.
Others may have had luck with peeling that last gel layer as well, but it’s incredibly stuck on. Best bet would be experimenting with some chemicals to dissolve it.
All in all, this is more of a temp solution in my eyes.
Greg841
106
33
WI
I got the last gel layer off by getting it started peeling up in a corner then grab it with a vise grip. Roll the vise grip back with a slow steady movement and peel up maybe a quarter inch, release, repeat. Just do little bits at a time. If you get greedy or try to rush it'll tear and you have to pick at it and start over. If you use heat it'll melt and tear. It'll take half an hour or more to do the whole thing but it's worth it. A little car polish cleaned up the remaining residue.
GMVguy
116
Texas
Did you happen to take any pics of the before/during/after?
alwayskaos
24
Lake Havasu City, Az.
Did you install the Ibis Tek windshields? I have no experience with these and I'm trying to gather the data to determine what I need. I do have a military contractor that has new heated windshields for these if your interested. Can I ask what the thickness of the Ibis Tek windshields is?
Greg841
106
33
WI
Of course I didn't, I was so excited it was working I never thought to take any pics :eek: I'll take some pictures this weekend though, I didn't use any black silicone on the inside edge to make it pretty so you can still see the layers that were cut out behind the frame.
Hell On Wheels
35
San Antonio, TX
Well, I have installed them onto a standard M998 with modifications They will install on a standard frame. You can check out all my mods and detail on G503 here is the link where I post all me work. I use the G more than SS using the same user’s name.
https://forums.g503.com/viewtopic.php?t=315674
To answer your questions here are a few phote of the measurmentets:
Send me a message about your Post of a contractor, I'm interested than doing all the work. I have to many other projects Im working on if I can find a faster way, contact me.
alwayskaos
24
I'm waiting for a price back. I should hear from them in a couple of days. I will let you know. They said the glass was 2.6", but he might have meant overall in the frame based by your photo?
alwayskaos
24
So the windshield replacement IBIS TEK units are not cheap. $1600 each. I have both sides coming. They are new manufacture heated and per mil specs. I just have to figure out how to remove the originals.
Hell On Wheels
35
San Antonio, TX
Finally got pictures. The white stuff is the gel layer that melted/oozed out when cutting the edges. If it ever warms up here for a couple days I'll get that stuff cleaned off, it looks like it'd be easy to pick off but it's hard as a rock!
Ok, I just want to understand the process. Looking at your picture Greg, when cutting we are talking about cutting the glass itself from the inside? What type of blade did you use?
Hell On Wheels
35
San Antonio, TX
Holy Diver!!!!!!!! Thats a lot of money for inserts replacement. I thought about doing that but before I wanted to know the pricing I tried to start to cut the seal on the outside of the window and man that is very difficult. I tired a test run and man I had not a good progress.
Greg841
106
33
WI
Yes, cut from the inside. You'll cut the entire perimeter about 1/4" deep, then heat/peel that layer off. Repeat the whole process one more time for the next layer. Then finally the gel layer that you pull off with the vise grip.
I used a wood/plastic straight blade. Going straight down until through a layer then pulling it out and moving over worked best for me.
Greg841
106
33
WI
Probably would be faster but I'd be worried about chewing up the frame with an angle grinder. With the oscillating tool you can set it right on the edge and it won't scratch the frame. You can feel when you get through the layers too, not sure you'd be able to feel that with a grinder.
alwayskaos
24
I'm about to remove the complete glass units for the frames I have, and I was going to put them in a bin covered in MEK. I was thinking if it sat for a day or two, the solvent would break down the sealant and the windows may be easier to remove from the frames. I'll post how it goes in a few days.
Hell On Wheels
35
San Antonio, TX
well, I figured out by just removing the plastic layer from the inside is easy but time consuming and the window turned out really nice and I'm working on the second window. I will be posting all my work on my G503 account as I progress with a link to my YouTube videos to share how to do it.
Hell On Wheels
35
San Antonio, TX
here is my posting working on the IBIS Knockout windows on my G503 account where I post my progress on removing the inner layers of the IBIS knockout windows, there turned out really nice. No more driving with them beer goggles :clinto::driver::usafss:Thanks to everyones inputs and ideas I could not have done this without :tank:.
final result video
Short videos of the progress of work
