My m925a1 build "Brutus"
muthkw25
789
Canton, PA
Decided to replace the ditch lights with the trucklight floodlights. They added a decent amount of light up high if needed off road. I moved the old ditch lights to corner of the bed near the market lights. This helps with visibility on the sides of the truck. Turned out well. Will need to test at night to see how it looks on the road.
muthkw25
789
Canton, PA
Mounting up a sound bar. Didn't want to drill holes through the fiberglass hardtop. Decided to use a 2x6 wood board. It fits snuggly between the fiberglass reinforcements on back of cab. Used gorilla max constructive adhesive. The board had to be hammered into position. Plan is to drill 2 small self tapping screws through the support into the wood to also help hold and stabilize. I'm going to paint the board marine corps forest green so it blends and then mount the sound bar.
I figured between the adhesive and the screws it should hold very nicely. Then I'll have some tunes in the cab. Ill be painting the 2x6 tomorrow.
muthkw25
789
Canton, PA
Got the sound bar mounted up. Used 2 deck screws with washers on each side through the fiberglass reinforcements. Painted the 2x6 marine corps forest green this morning. Mounted sound bar. The power cable doesn't allow me to have it face directly out where the brackets are so its facing up. Works like a charm. Now I can blare fortunate son while hauling the mail.
muthkw25
789
Canton, PA
Picked up a #25 and #22 fuel button. Going to swap in the #25 and might do the #22 depending how fuel pressure is. I wouldn't mind a little more power. I also want it so anyone can get in it and drive it without worrying about temps, fuel pressure, etc.
I picked up a new engine filter and engine oil, can't believe its been 3k miles since owning.
I'm wondering what others are seeing for fuel pressure at a #25 and #22 button?
muthkw25
789
Canton, PA
Took the m1061a1 trailer out. First tow since the turbo build. Truck pulled well. 800 egts on hills max. No temp and fuel pressure issues. Boost saw max of 7lbs on #27 fuel button. Still planning on the 10% over injectors and might do a 25 or 22 fuel button. It holds speed on hills but would be nice to have a little bit more acceleration. Pleased with its performance. 60 degree day today.
muthkw25
789
Canton, PA
Took Brutus on vacation to Gettysburg. Did 400+ miles towing the m1061a1. Truck did fantastic. Maintained speed well, only dropped back to 47 or 48 mph on some grades. Highest fuel pressure was 150 to 160. Highest egts was 850F. Highest boost was 7.5lbs. All on stock #27 fuel button. Maintained speed at 55 to 58 with the 395s turning 1800 to 1900rpms. Got 5.5 mpg towing the 8k lbs trailer.
Truck performed great. Very pleased with performance. Soundbar in the cab is a must for long trips.
muthkw25
789
Canton, PA
Installed a new thermostat gasket and seal since the housing was leaking. I also replaced the coolant temp gauge. Driving home it failed. Gauge face broke off trying to take out old gauge. New one working like a charm. Matches other gauges.
I know the white gauges aren't period correct but super easy to see in low light and when facing the sun. Very visible. Not blinding at night either. Highly recommend this series of gauges if you are looking for an upgrade.
Got a brand new gear reduction starter. Old starter is starting to stick. Will have rebuilt. Figured the reduction starter will spin slightly faster and draw less power on startup.
muthkw25
789
Canton, PA
Installed the gear reduction starter with my Dad. That was challenging. 68lb starter in an awkward position isnt fun. One bolt is a 5/8" 12 point. The others are 15/16". You will need some extensions for the one inside the starter next to the block. The star shaped bolt head needs a box wrench, preferably a ratcheting box wrench.
Dad attached a ratchet strap around the body to the steering column and a strap to the ground to help raise it up while I helped guide it out around the wires.
Starter could not go out the bottom without moving the front drive shaft.
Took about 2.5hrs to install. Its difficult with the truck sitting so high trying to help it from the bottom.
Starter is quieter and spins a tiny bit faster. Old one will be rebuilt and used as a spare.
muthkw25
789
Canton, PA
I had the injectors put in yesterday. Went to the local heavy duty truck shop and owner helped me with inner base valve and injector setting. I did outer base when doing just the valves before. Was good to learn the other way of adjustment.
The truck fuel pressure dropped from 170psi max to 150 max. Egts are the same. I did notice some gain in 4th and 5th when accelerating and holding hills but no real boost gains. Which is odd because the injectors are 10% larger. The owner of the shop said its the cleanest exhaust he's ever seen under full throttle pulling hills and recommends a larger button. Im going to play around with the buttons. I have 25,22,20 and a 17. Im going to try a #22 and see where the fuel pressure is.
Id like to get the pressure to 180 give or take and see how it performs. Overall injectors were a success and im glad I made the change. More updates as I play with the button.
muthkw25
789
Canton, PA
Installed a new idle plunger today. Pump was built with a #27. I installed a #22.
I saw 9lbs of boost. Egts at 900F to 950F. Fuel pressure is back to a max of 170 like it was prior to doing the injectors. Truck feels strong at 1900 to 2000rpms. At 55 to 60mph pulling a hill I could maintain speed and feel it push you back in the seat. Truck is turned up as much as im willing to go. My wife could drive it safely. Other than dialing in the methanol kit and a larger intercooler, the trucks done with performance upgrades.
Took the truck to my nephews 3rd birthday party and he wanted a ride in the "big truck." We also got him a tough trucks for kids "tank" so he got his first military vehicle. Id say he loves it.
US6x4
2,534
Wenatchee, WA
Your efforts have paid off and your truck has got its 15 seconds of fame!
Sgt. Tibbs might be a bit jealous and may need some consolation pets or maybe a cat video compilation to watch...
muthkw25
789
Canton, PA
Thats cool! Had no clue. Sgt Tibbs would love it. Sgt Tibbs passed in May. He suffered significant bladder crystals. But hes not suffering anymore.
muthkw25
789
Canton, PA
No, they're still stock. I need to address the air restriction of the factory air cleaner first to make the turbo happy.
Someday I'll think about upping the injectors but for now it's not a priority.
I went with those military guys filter and assembly and it works real well. Based on my boost im at probably 900 to 950 cfm. You also have a much shorter distance from filter to turbo. Would their kit work in your housing?
US6x4
2,534
Wenatchee, WA
Yes, it would work. I can't remember...does it require cutting out existing baffles and such?
