My m925a1 build "Brutus"
hethead
228
Seattle, WA.
Thanks for posting the follow up. "Cummins turbo'd the NHC 250 (making the NHCT 270) and so should you!" That's a nice, well thought out set up you have. I wouldn't be surprised if your boost goes back up a few lbs after you put the higher flow injectors in. You have lots of room to safely add more fuel with those EGT numbers.
muthkw25
756
Canton, PA
Thanks hethead. I'm guessing it's probably around there. The methanol kit at this point is not worth the investment unless you just want it because. Im going to remove it and save it for a future project.
It might be better to have methanol if you don't run an intercooler to help with the higher intake temps.
hethead
228
Seattle, WA.
I'll probably see how it goes first before adding methanol.. I've grossed 67,000 but I didn't go up anything too steep. My goal is 60,000 when I start putting in real miles and going over the Rockies again, etc. So I'll see how it looks on the long pulls and go from there. I'd rather have and not need. I think the main thing is to get the whole engine block good and hot before leaning into it and swelling those big pistons up too quickly.
muthkw25
756
Canton, PA
I agree. For my application I won't be using it anymore. Maybe with 16r20s but not these.
I only give it what it will take.
muthkw25
756
Canton, PA
Here's a drive by at 60mph. Next one is coming back to the shop after a 15 miles test drive.
Ill get some video in the cab and record a longer trip in near future.
muthkw25
756
Canton, PA
Got the gauge installed. Put a T fitting at the block so I can run a fass down the road. Used a 24v led green bulb like other gauges so it works with high/low function. Purged the air from the gauge. Gauge reads 85psi old. Old gauge was 60psi cold. Overall pleased with results. I am going to get an angled cup so I can angle the gauge more towards the driver so it's easier to read. The face has a larger lip so it's harder to see some of the numbers, especially on the smaller gauge. This should correct it.
Sgt Tibbs came out to help and he didnt want me putting him down.
muthkw25
756
Canton, PA
Thought I was out of the woods but putting the gauge cluster back in caused a leak near the fitting at the gauge. Not much room behind that cluster. Luckily I had some -4an ptfe line with fittings. Can support more pressure and larger diameter. I moved the location of the line and I'm going to try again tomorrow to see how it fits. It's difficult because you can't see much from under the dash.
More photos updated tomorrow.
muthkw25
756
Canton, PA
No leaks! After truck is warm oil pressure drops 35psi at idle. Under throttle it's about 70psi warm. Much more accurate than the old sending unit. Truck ran flawless. Below are some posted links of the truck with the gauges showing pump pressure, egts, boost, etc.
muthkw25
756
Canton, PA
The seat shock finally bit the dust on the videos posted above. Ordered a new monroe 66104. It's used in atvs. Gas shock. It's 1 inch shorter give or take than the military shock. I have put them in 4 deuce seats and they work awesome.
muthkw25
756
Canton, PA
Got the shock today. Talk about a waste. We wonder why cost is up in America. This giant cardboard box for the smallest shock. Also a side by side comparison for those that are looking for a good alternative to the military shock.
I had my Fiance step on the base so I could get the top bolt in. It was not easy.
Being 7 ft off the ground and trying to reach in tight spots wasn't working well. It was a nightmare. Usually I have taken the seats out to replace these but didn't want to remove the insulation.
Now when you sit in the seat and jump up it comes down nicely. No more bottoming out. I sit about an inch lower to the ground which works for my height. It's a $45 shock. Worth the investment.
muthkw25
756
Canton, PA
Decided to paint exhaust stack. Scuffed with sandpaper and cleaned with xylene. Used high temp primer. I tried to tape off as much as I could. Once it dried I applied high temp flat black. Rated for 2000F. Should hold up. Gotta fix overspray.
I also got this reflective heat blanket for the coolant lines. It's 2" or 2.5" in diameter. I added a second layer of silicone hose over the main feed under the cab and then wrapped all 3 coolant lines with this wrap. Can sustain 500F touching temps. With the exhaust wrapped and space under the cab and then the lines covered i shouldn't have any issues or worries with the heat causing any failures.
Next step is to let paint dry for awhile and do touch ups and then paint the rims.
muthkw25
756
Canton, PA
Spoke with Warren at premco about running a Fass. My buddy runs one on his m925a1 and I was considering it. Warren stated he would not run one. If you choose to run a lift pump he said 5-8psi max. The pump is designed to pull vacuum not take pressure and the PT Pump can be over pressured easily. He doesn't run one on his race truck.
I know there's a few on here that run the fass and haven't had issues. I just had the pump rebuilt so I'm going to play it safe. Just some info for those that might consider one down the road.
muthkw25
756
Canton, PA
Repainted the wheels flat black. Finished touch up paint on the stack. Also decided to change the towbar color. I painted it semigloss black. Will give more contrast mounted to the bumper. I also got a good deal on some trucklite military led flood lights so im going to run those for ditch lights. The other lights are much smaller and not covering as much as I'd like. More photos to come.
