Polaris MRZR-D4
gottaluvit
Ok. Lawdog is making a list of parts so heres a fact. My left rear outer joint in the axle broke a while back. I checked the specs and it looked like an outer joint for an xp1000 would work. So I found an entire cheap junk axle to purchase on ebay to test fit. It was cheaper to buy a cheap junk whole axle than a cheap outer joint, so I did. What do you know, the entire axle was a perfect fit. Seems these machines have a locked rear end and it ate that china trash's outer joint up in a few left turns on asphalt. So I found a deal on ebay for an open-box Rhino Axle and that one is still on and perfect, many months later. Hope this helps!
Lawdog734
158
Colbert, GA
So, the outer CV joint works and can be retrofitted to the MRZR-D4 axle, or the whole axle worked?
Cobra Axles in Houston, TX made me an axle, for not nearly as much as one would think. It'll be delivered tomorrow, and I'll update everyone if their drop-in complete axle works. Hunter at Cobra is very familiar with the MRZR, so it should be good to go if it fits.
gottaluvit
The whole axle works! Just remove the old and replace with the new.
Lawdog734
158
Colbert, GA
I didn't take any pics, but Cobra Axles in Houston made me a spec rear axle for the MRZR-D4. The fit is exactly like the OEM axle and it's definitely beefy.
While the Rhino 2.0 may also fit and will save you a few bucks, it's nice to know that there are options out there in the event that we need spares.
Cobra Axles Link
