Another Ahab
- 4,901
- Alexandria, VA
Wow. Unbelievable!The rainbow was amazing, a rare occurrence. A couple more shots of it
Update on the LMTV cab swap: the cab is bolted down properly. Back-of-cab hooks are adjusted but I’ve got work to do on the cab latch. Good news and bad news, good first: after a week of troubleshooting I got Goliath to start and run, only the fuel gauge inop so far, probably connector. Bad news: spent a week troubleshooting “failure to start” problem. Between the -20-1 and several contributors here, found the problem. Somewhere between pin 87 of relay K1 and TL33 on the Aux Starter Relay there is an open connection. Absolutely everything else tests good including oil pressure switch, trans control module and VIM, relays, circuit breakers, wires, grounds, etc. I need to check the back of the PDP and make sure that socket is ok but otherwise, I’m much happier. Long road to “complete” but this is the biggest and toughest hurdle.
Will start another post about the broken wire…
Am doing the Snoopy “Happy Dance”. Am tired too…
Thx all!
A lesson from the Stoics of Ancient Rome:Actually, in deciphering the electrical schematics, both the fuel quantity wire from the sender to the gauge as well as the below wire from K1 to the Aux Starter Relay run through P43 under the main dash panel. I'm going to start there and do continuity checks both directions from there. Stupid me, it may be unplugged from troubleshooting this problem initially. Would be just my luck.
More to come...
- Laugh WITH the Gods, while they are laughing at you
Because there's plain nothing like a good laugh!
