poppop
- 39
- 48
- Brooklet, Ga
When the motor is turning do you get smoke out the pipe? I started one yesterday that had been sitting for years. First attempt no smoke but I let it spin to build up oil pressure to get it lubed before starting. I suspected the shut down lever in the pump was stuck in the off position. Pulled the cover off the pump and it was stuck. Freed it up and she started right up and ran great. I was going to dump the fuel but it looked and smelled good so did not. This is the second truck I have had that the shut off was stuck in the off position and had to be freed up.
