I changed the picture above, to one that is less confusing(sorry). In the new picture, it is now obvious where each wire goes. The "lower" purple wire has a white stripe.
Here is a description of each wire.
Top post ,red, 24v+ supply
Top post, purple, to starter solenoid
Bottom post, purple with white stripe, 12V + from key in start position
Bottom post, black, chassis ground (12v negative)
Be sure to remove BOTH, your front battery negative battery cable and your rear battery positive cable, while doing this modification.
Same picture as above, to make it easier to read this and see the picture.
