Bob H
- 167
- 63
- Huron National Forest, Michigan USA
Have an air leak under the dash, thought it was the line to the gauge , and it just needed tightening. Well it isn't the connection, it is a cut in the hose, which had a piece of aluminum wrapped around it, this piece of aluminum was manufactured and not a rig job. Is that a typical repair? or just a protective band that is supposed to keep a rubber hose from getting cut, and somebody at the motor pool used it as a 'non-regulation repair.
I would just assume replace the rubber air line, I misplaced my cd manual, so I can't look up the part#, Where can I get one?
