- 753
- 202
- 43
- Gainesville, FL
Noob question here, so excuse me if this is an ignorant post. I have got to learn about these trucks somehow.
My M35A2 was delivered to my job site on Thursday via flatbed. It was in 6x6 low range when it was backed off the trailer. I put the truck in neutral, flipped off the air shift front axle and pulled the range lever to high. There were no problems when I pulled the truck over to it's parking spot and inspected the fluids and air the tires.
Later that day, I drove it approximately 32 miles home. Mostly at highway speeds. 50-59 miles an hour. (I know not to exceed 56, but it just sort of happened.) Here's my problem. Right around 55 mph, the truck tends to wobble from side to side any time I turn the wheel to follow a bend in the road. The truck drives perfectly in a straight line, but when I turn, it shakes left to right. Anyone know what could cause this? Is it normal?
The truck doesn't pull when moving in a straight line. Maybe the fact their are 8 tires moving the truck forward, and only two in the front trying to turn are causing the front tires to hop a bit while turning.
