I think I may have an oddball turbo...
fabiodriven
East Bridgewater, Mass
So I'm looking to get the "Whistle" from my deuce. I thought I had a D turbo because my deuce doesn't whistle. So I order what was supposed to be a C turbo, it shows up, I put it on, no whistle... Now I have the two side by side on the ground comparing them and one appears to be a C and the other appears to be a D, but neither whistle. I came inside to look at some pics in here and find out what I have and here's what I gathered-
The C turbo has a band connecting the exhaust housing to the turbo, the D is bolted.
The C turbo has the snail shaped exhaust turbine, the D is fatter.
I have one turbo with an exhaust housing connected with bolts, one with a band clamp. Assuming the one with the band clamp is a C, why doesn't it whistle?
Another thing I have noticed looking at pictures- My so called C turbo has a compressor housing that I haven't seen in any of the pictures camparing C's and D's. It is much fatter than any of the pictures I have seen. So it has the C exhaust housing with what I will call a "mystery" compressor housing. Any ideas what this turbo might be? I will have pics up at some point, camera isn't home right now.
wsucougarx
65
Washington State
Yah, there are some good searches on the LDS motor. Seems to have a higher HP rating but does use up more fuel than a LDT engine. From a HP standpoint, I think the LDS is more desirable:wink: I checked out and LDS turbo'd engine 2 weeks ago and it did have a faint whistler sound to it.
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
I have a D turbo on my LDS and it has a slight whistle to it too. I will be putting an LDS turbo on my wrecker this summer, Will let you know the difference once thats done.
Desert Deuce
19
Chino Valley, AZ
LDS in a Deuce = Good. Turbo can be changed. There are a few of us here that have LDS's in our Deuces. I think you hit the Multifuel jackpot.
My truck below has rings on the bed as it was a shelter carrying truck. It also has a box seat, which I like.
Speedo on this truck shows 280 miles and about 40 hours. It has a newly rebuilt LDS.
Was purchased from GL with the LDS. Didn't know it was there until after win..
gimpyrobb
27,791
787
Cincy Ohio
HAHA! I have an LDS in my latest deuce and in the wrecker. The non-turbo M109 is now horribly underpowered! glad I have an LDS in the can waiting to go into it too.
NDT
7,433
Camp Wood/LC, TX
LDS does not make the "whistle" that the "whistler" turbo truck is known for. You can hear those coming from blocks away. At idle the LDS turbocharger is quiet. It starts to scream when the engine is loaded and boost is produced. The sound is more like a jet engine.
fabiodriven
That is also correct, it's like a jet engine or a more modern turbo-diesel. I want the "blocks away" sound from the C turbo. I wonder if anybody knows if I put the C turbo on the LDS if it will have that loud whine. I would imagine it would.
gimpyrobb
27,791
787
Cincy Ohio
About 50 more hp. I have heard that only they have piston skirt oil jet coolers, but also heard ldts do too.
