I think I may have an oddball turbo...
grounded
Banned
928
defiance oh
LDS is a 5 ton multi engine
LDT is a 2 1/2 ton multi engine.
the LDS has more power and more wanted in a deuce. If you dont like the LDS and got to have a LDT ill swap you rofl
scooter01922
42
Newbury, MA
Pretty much more umph. The LDS is the 5 ton multifuel and is rated at more HP stock. Makes the underpowered deuce a bit less underpowered.
1,827
Lets clarify some stuff here. The pic posted in post number 5 is in fact a turbo off an LDS. We need to now clarify that it is off of an LDS 427. Fabio, you need to clarify if you have the LDS 427 or the LDS 465-1A. The LDS 427 is the older deuce engine from the M35A1 and suffers from reported reliability issues. I have no experience with these engines. One of my recent deuce purchases had an LDT with this turbo. If you have the LDS 427 you will likely notice no benefit. The LDS 465-1A is from a 5 ton and does have about 50 more HP. Also note that the original LDS 465-1A had a gated turbo that is significantly bigger. Lots of them were replaced with "C" or "D" turbos at maintenance level. I don't have any numbers as to the benefit of the gated turbo. My recent LDS 465-1A had a gated turbo on it when I first looked at it, when I went to get the engine, the gated turbo was gone. I can't get my money back, the engine was free!
Hope this helps!
fabiodriven
East Bridgewater, Mass
OK, well I have the LDS 465 1A, so I geuss that's good. Brings me up to, what, 190 HP? Well the LDS is a plus I guess. Now hopefully it will whistle with a C turbo. Thanks alot guys.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Yes, the gated turbo is what I was talking about. When I get it on my wrecker, I will let you know if it makes much difference and what it is.
tm america
25
merrillville in
thats the same one i have on my truck .its makes way more boost than any ive seen.my truck makes just under 30psi boost .and i just turned the fuel up a little bit i get about 12 mpg driving normal.no whistle at idle but you get a little at 1600 -2600 but not much:roll:mine is a d motor from the plate but was rebuilt by the gov in 92
tm america
25
merrillville in
i would guess my truck at around 200 to 210 hp i can maintain 70 even while pulling 10000lbs on the trailer up slight hills.oh i have 15.5s on there and still takes off faster than with the 9.00s seems more load =more boost and more power .doesnt slow down till i get around 20000 on the back
