Unfortunately I don't have any tested IP units, I will be bringing an IP from an engine that was apart when the truck came in......selling it as a ???????I could use a working IP pump for the 6.2 engine.
Your in luck! I just tore down a truck for the engine yesterday, trans couldn't be easier to pull!, $200.00, unit is guaranted. Let me knowWhat about a tranny for a pickup i need a 400 tubo![]()
No luck on the dashpad...would a door shell,(no guts/glass [use yours]) be OK?Looking for a clean driver side door to replace one with major forklift damage. Also looking for a clean dash pad.
Lance
4 wheelsHow many wheels do you need? I'll definately remember the tarp![]()
I can hook you up with three sets, these are everthing on the frame, brackets, re-enforcing plate and some still have the bolts as I just cut the end on the frame off to keep it complete. $50.00 a pair so three sets are $150.00I'm looking for 3 or 4 sets of the tubes where the shackles mount. Don't need the shackles just the tubes where they mount. I would like to set up some of my non MV trucks so I can use my MV Towbar. How many do you have and price ?
Thanks
Found two and are ISO for two more.....I'll let you know4 wheels
