- 2,799
- 73
- 48
- Mesquite, NV
After I swapped the rusty roofed M109 box for a clean cargo bed I discovered the mounting for the pioneer rack was a little different. I've been meaning to fab something up to get it reinstalled, but have been dragging my feet. I thought about putting a toolbox there and when Phil mentioned he was thinking about the same thing I decided to make it happen. I went with a Craftsman "middle" box because I didn't want a lid and the smallest bottom box would be much too large. I stopped by Sears and had a choice of 6 different ones. I could've picked up a scratch and dented pro box for $110 or something new (still with roller bearings) for $89. Then I saw a low end homeowner series on sale for $35. It installed as if it were made to go there. I still have some drawer liners to put in and then I will get all my lightweight tools moved over. The liner foam I'm using is the same stuff we use in the Navy - about a 1/2 inch thick. You trace the outline of each tool into the foam and then cut it out. When your done each tool has it's own place and it holds them in pretty well. You can tell if a tool is missing quickly too. Here's the pics -
