tm america
- 23
- 38
- merrillville in
hmm that sucks when it happens like that..i hope i can still drive mine home when mine blows up to make room for a cummins
800sq ft ish Man Cave. . . .What's the room that is insulated, in the right rear corner of the shop? Is that a walk in cooler?
Ed, you think getting it out with the winch in place was fun? Just wait until you put it back in.
It looks like the rod bolts failed, the crank smacked the dangling rod, ripped it out of the piston, and then ejected the rod out the drivers side of the engine block. The piston is at the top of the bore, the rod cap and some small pieces of piston are in the pan. The crank is damaged beyond repair, not sure about the cam, but it's right there with a courtside wiew of the carnage that happened. . . but the side of the cam I can see isn't scratched, maybe I'll get lucky!
I think I called this back when you first posted pictures of the event.My money says that the remains of the piston are still residing in the cylinder liner.
With this engine using an offset connecting rod cap, it appears that one rod bolt failed liberating the connecting rod, which was in the way when the crankshaft continued rotating. The crankshaft struck the connecting rod and forced it out the side of the block. http://www.steelsoldiers.com/attachments/deuce/155043d1259437900t-55mph-detonation-carnage-002.jpg
The rod bolt as you stated probably was over torqued and stretched. Spinning four plus pounds of piston/connecting rod at 2500 rpm for long periods of time is a recipe for failure.
