jesusgatos
- 28
- 38
- on the road - in CA right now
My sprag case blew-up a while ago, and M715 hooked me up with a great deal on an air-shift transfercase with a PTO unit. So now I'm finally getting around to swap and I've got a few questions.
I've already dropped the old case, and that went really smoothly, but is there anything I can check to make sure this air-shift transfer-case is in good working order? I mean, besides pulling the drainplug and hoping that metal chunks don't fall out.
Anything I should do maintenance-wise before I install it? I'd like to replace all the input/output shaft seals, but I didn't plan ahead, so I was going to order those on Monday and then just replace them after I've installed the new case (before I re-install the driveshafts). Doesn't look like that should be much of a problem to do with the case in the truck.
What about the PTO unit? Doesn't look like there will be much room to remove/reinstall it with the case in the truck, so I'm wondering if that's something that might need any attention now.
I just don't want to have to drop this transfer-case again. Ever.
