Alucard-HD
- 0
- 0
- PA
Anyone swap rear disc brakes on the M1008/M1028? I saw ORD's rear disc brake kit. it was a good price and it uses chevy 3/4 ton front calipers and rotors. Just wondering if it was worth it.
Yea, thanks man. I have disc brakes on my 2500HD and they work great, that and they are easy. Thanks again.yes it takes about 80 pounds off the rear end of the truck plus you get better breaking
this is the guy i am going to use for the conversion
Dana 60 or 14 bolt disc brake kit $315 shipped - Pirate4x4.Com Bulletin Board
Cool, thanks man. ORD wanted 140 for the brakets.looking to do the same.. never saw a kit like that.was told you can do it yourself for about half the price of that kit. the brackets i found where 45 to your door. will put a link up when i find it
Did you need to adjust the Proportioning valve?I got my brackets from Greatlakesoffroad.com 50 bucks works fine truck stops on a dime.
I agree, i think only 1/2 and 3/4 ton calipers and rotors work with these kitsDoes anyone make a kit using the same calipers and pads as the dana 60 in the front? It would be nice to use the same pads on the front or back.
