- 2,799
- 74
- 48
- Mesquite, NV
If you had a driver for the deuce and it had good brakes you could "move'" it successfully from one location to another. Provided the road conditions were right and each driver had a decent amount of common sense and teamwork.
If I were broke down (say engine related) a short distance from home, I would probably just drag her home. It just depends on where it's at and where you're trying to go.
It sounds no more unsafe than putting a dumptruck, a genset and a few dogs on a gooseneck and dragging it with a lifted ole 3/4 ton. And everyone applauded that.
If the deuce you're trying to move has no brakes you're outta luck IMHO.
This would be ILLEGAL in pretty much every state, your milage may vary, objects are closer than they appear.
