Read the TM I referenced: "Release clutch pedal slowly AND depress accelerator pedal to increase speed..."chuck, i think there's a gap between what you are saying and what Tom is saying.
when you spoke of slipping the clutch, you also mentioned applying engine throttle.
Not: "Release clutch pedal slowly and then depress accelerator pedal to increase speed..."
It's a nearly simultaneous action. The engine is not intended to be supplying a lot of torque at idle. In most circles that is known as lugging the engine.
I am not talking about aggressively slipping the clutch all the way up to speed, but you do have to slip it from stop to about 3MPH when you start out in first gear, and about 5 or 6MPH when you start out in second gear. The slippage to get up to "Idle" ground speed in first takes a fraction of a second. It takes plus of a second in second gear.
All things equal, it shouldn't take too much thought to figure out which is harder on the truck, and the clutch.
When I teach new drivers how to work a clutch, with gas or diesel, I teach them about clutch control by having them start unloaded on a level surface at idle.when Tom speaks of not slipping the clutch (as have i), he is just talking about easing the clutch out with the engine at idle. yes, obviously the clutch still is slipping some, but not near as must as, say, driving a gasser car and having to apply gas and clutch simultaneously. so, if you have to apply throttle during let-out, then your idle is too low, gear selection is too high, or the truck is laden.
You can start any vehicle that way. That doesn't mean that it is an optimal solution. Just one of the boundary conditions.
But by stating it the way you and Tom are (You don't have to slip the clutch!), you are divorcing the entire clutch/accelerator pedal action by just stating one boundary.i drive how Tom refers - let the clutch out to get you moving. once the clutch/engine rpms are matching and fully engaged, then apply throttle. this manor only exposes the transmission to 'let-out torque' of the engine from a stand-still.
driving this way (in whatever gear you want to start in) virtually eliminates torque spikes through the trans. this is also the method used by OTR drivers..... well, those that still shift, anymore.
When you drive, you have to adjust your methods to incorporate any degree of hill, and any degree of load. That means that you are going to be slipping the clutch to a varying degree, and applying the accelerator pedal at start up to a varying degree.
To say you are not is disingenuous.
[uhmmm, misleading would be a nicer word - chuck]
-Chuck
