Stouttrout
- 0
- 0
- Sour Lake, Tx
Going to recover a Tank truck i bought. It is not far from the house. maybe 15 miles. Any Advice on using the tow bar? it was killing me just sitting there so i had to buy another ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Pull the shafts on the rear? Good deal. Why the intank fuel pump? Not a problem just curious.Pull the spline caps and the axles. Unplug the intank fuel pump, turn on the hazard lights. Set it all in motion.
You can also tie off the steering wheel with some rubber tarp straps......the straps will pull the wheel back to center when you turn a corner.Have someone turn the truck at the 3 corners.. they like to turn the opposite from what I have seen...off pavement ..That close you have it made!!!!
I plan to
I'm just a little lost with the in tank pump thing here. Are you folks suggesting that the accessory power switch needs to be on to run the emergency flashers?
