Large and "OMG it's HUGE" towbar feet to tow a deuce?
TexAndy
15
Bee County, Texas
I bought one of those lots of towbars out of pineville a few months back. Had several of the "large" towbars, some with feet. And it had several of the "hold my beer while I give myself a hernia" towbars. Also, some with feet.
The "large" ones have 1" pin holes where the feet attach to the tow bar, but 1.5" holes where they attach to the truck. No go for a deuce. The deuce tow points have 1" holes.
The hernia makers that came with feet had 1.5" holes both where the feet attach to the towbar and on the side where the feet attach to the vehicle.
Did they ever make feet for either of these towbars with 1" holes?
If not... would it be safe to try to sleeve the 1.5" holes down to 1" ?
Just out of curiosity... what were these ballbustingly heavy towbars used for? I can't even lift an end without taking them apart.
73m819
319
gainesville, ga.
nopics
I have the tow bar from he11, I did find a set of adaptors with the 1"tow hole from somebody on site, I think SEMIS
there is not enough clearance to use the 1 1/2 pin hole with bushings, the adapter won't fit
jh1990
just a guess but i'm going to say the "ballbusting" ones are from an M88 Hercules tracked wrecker, and the other one sounds like the ones we have at work off our M984 wrecker for our M1070 HET systems
mkcoen
381
Spring Branch, TX
Scrap those and buy a medium towbar. Or better yet get that stinking 816 running so we can go play with it.
TexAndy
15
Bee County, Texas
I'd get it up and running and immediately get pulled over by Officers Knuckles and Fat Tony for failing to give the government it's protection money on such a large and obviously commercial vehicle. You know, because it's a dangerous road out there... you need protection. Accidents happen.
Here's pics
Huge one:
About 7 feet.
8383808 on the tow bar.
12322862 on the feet
"Large" tow bar:
Also about 7 feet long.
Number on the feet looks like: 19207 - 11660834
Number on the large bar looks like:
7263789
044
73m819
319
gainesville, ga.
the distance between thr pin hole on the lift bracket and the bumper is not enough for the 1 1/2" adaptor to fit
mkcoen
381
Spring Branch, TX
Get the correct feet and you can use my towbar any time. Now that I have a tow "vehicle" we can try some recoveries that aren't "I think (hope) I can stop with that behind me."
73m819
319
gainesville, ga.
no, I did that, the adaptor tip WILL NOT FiT, it wont pivot, that is WHY I bought the 11/2" x 1"adoptors
73m819
319
gainesville, ga.
not taller lift brackets but the correct adaptors, the taller the bracket is , the more SIDE pull or twist in turns
TexAndy
15
Bee County, Texas
I guess I'm just not picturing what the problem is correctly, then.
I thought you meant the hole on the bracket was too close to the bumper to allow the tow bar enough pitch movement.
What does this adapter that you bought that works look like? What's it called?
73m819
319
gainesville, ga.
" thought you meant the hole on the bracket was too close to the bumper to allow the tow bar enough pitch movement."
that is correct, making the lift bracket higher to provide the need movement required will put a LOT more side load on them in tight turns
ill get some pics later,my camera is dead, need my wife to do the deed with hers
