DokWatson
- 0
- 0
- Wasilla, Alaska
I have seen this done as well. Buddy of mine has a manual tranny mated to an automatic tranny. Lowest gear is reverse/reverse, somewhere around 250:1 crawl ratio. Its a 4x4 though.My "crazy" plan was to, if your making it a 2wd,was to put 2 transmissions in it. I can post pics of my dads wrecker(chevy also so you can do the exact same thing to yours). He has a granny 4 speed with a Watson 4 speed behind it. Shifting it could be compared to a 13 speed in a semi.
That's great info. Thx Westech.ok guys.. here is the deal. #1 bump timing a bit #2 turn up fuel 1/6 of a turn #3 install new marine injector tips ($65 for alland install new injector return lines ($25). The return lines dont give you power, just the factory ones will brake off. If you can change a spark plug you can install a new injector tip. Its that EZ. This will net you a close 200 HP.
why would it be better?A 4l80e would be a better choice for trans. Its basically a th400 with overdrive. Cheapest route would be to get one from a wrecked truck. I think GM started using them in 91
the truck is setup for an auto now and id hate to have to change it back lol but being in florida hills is no problem. a cummins is a long range wish but i have to get rid of this 472 cause 8mpg is killing me.I did a frame off on a 66 k-20. It had a 292 chevy and 4:56 gears. 4 sp manual. great truck, but rusted from the inside out, no matter what I did. The GMCs often had the V6 305 or 351s. A very good gas motor, used in a lot of school buses of the era if looking for parts. The 6.2 will be fine if only used locally and you don't have too many hills. Otherwise, you will need more power. I would go for a Cummins, if you can afford it, but you should use the cooling system off whatever Dodge you get the engine from.. and use a 5 sp, not an automatic. If you want to be psycho, put a Detroit 451 or 471 and an extra gear box. Nice truck.
i want a diesel tho. if i was going gith gas i would do a 318 or a 302 or maby a 360If you are doing it on the cheap, the 6.2 is the way to go. Dirt cheap (for a diesel), parts are plentiful, much easier to adapt to your current drivetrain and they wind up a little tighter than the Cummins. As others have said, lack some power. I'd say it would run with the 305 V6 or the 292 I6. Needs one power wire to run, and a manual GP system is real easy to set up.
ya well i like them dumb slow and strong lolThats what I was saying, the 6.2 would have at least the amount of power as the 305 or 292, both common engines of that truck and time. No way it will run with the 472. That 472 will pass everything but the gas station. I think the 6.2 is an ideal engine for you r application, just don't expect 472 power!
It's just an overall better trans then the 700r4. And would be a better choice for the diesel power, heavy truck, and towingwhy would it be better?
