ZRacer
- 0
- 0
- Valley of the Sun, AZ
Hello all,
I am the proud owner of a 1970 M35A2C with a D turbo, full bows and cover, less than 140 hours on the engine at the time of pickup (51K miles though). I drove it back from Santa Clarita, CA to my home in Arizona. Let me tell you, 400 miles (it took about 10 hours), in a hot, dirty, LOUD, bumpy military vehicle was not a trip that I will forget (and I loved every minute of it!
)! An eBay deal for $3100. It ran GREAT all the way home, never got too hot, even through the desert at 104 degrees F, and climbing those hills (only had to downshift to 4th twice the entire trip).
There are some problems that I need to take care of, however. First, the steering wheel has all three spokes cracked - definitely concerned about that. I think I need a new one.
My engine stop pull handle is sticking (doesn't work - I am having to kill the engine by starting out in 5th gear and stalling it - not the best way, I know).
The parking brake is stuck and I can't pull the handle up - any ideas? Horn doesn't work - maybe it is just disconnected but I haven't had a chance to check it yet.
Wipers don't seem to work (not that I will likely need them much in Arizona!).
Tires - many have sidewall cracks - how do you know when the cracks are so bad that you need to replace them?
My driver's side window is badly cracked, but they gave me a new one (in a box) with the truck. Is it easy to replace by a novice or should I call a glass shop?
Some minor rust around the tailgate. Is it enough to just take a grinder to the rust spots and then spray some flat black Rustoleum on the spots or is there a better way (short of re-painting the entire truck or tailgate)?
Thanks in advance for any advice!
![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
