wehring
- 25
- 38
- Angleton, TX
Alloy
You can run Alloy 22.5s... painted OD of course.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Justin Wehring
979 997 3112
Justin Wehring
979 997 3112
Not through the drum itself....!found this picture in another thread...
http://www.steelsoldiers.com/attachment.php?attachmentid=209564&d=1288606715
can anybody confirm that the sheel studs onthe front hubs go through the brake drum?
but it does go through the drum adaptor - ok good to know. minor effect on the adaptor design. different bolt length for the front and rear adaptors.Not through the drum itself....!
G.
Personally, I don't care. Sounds like the best/easiest option to me....the best way to attach the adapter doesn't allow you to put the studs back in later - it's permanent. that's really the only drawback.
Exactly! I wrestled with this, and decided to re-center the stock wheels, but if/when I ever plan on doing any extensive traveling overseas, I'll almost definitely switch over to 10-lug 22.5 wheels. In the meantime, I'm going to take advantage of the cheap 20" 11.00 surplus tires, and the HEMTT wheels are too wide to run those anyway....it's also really hard to find surplus 20" tires in other countries but 22.5 are available at any big rig tire shop.
Where are you getting 6 hemtt wheels with adapter plates for less than $700? I'll buy a set right this moment if so...I think $1500 is too much. You can get a set of 6 HEMTT adapter plates for less than $700. I would pay up to $1000 for the added versatility, but not $1500.
