towing info for the bigger trucks
krall
shippensburg PA
I agree a wrecker would be better, weight in the back would definantly help, Can I ask how do you get the brakes in the back hooked up? do you need another air supply line or are the ones on the back up for a trailer removable? Its dark out or I would go look!
krall
shippensburg PA
I know for a street legal vehicle it is required but wasn't sure if the fact that it was being towed made difference, of coure the tires are still turning so they are capable of throwing stones and junk so I guess I should have just took a second to think, anyways thanks
Coldfusion21
Tualatin, Oregon
Like for towing? the front glad hands provide air for the entire system, rear included. If you can not provide air then the brakes need to be caged.
I NOW HAVE BOTH A M915 AND A M818 AND MY CHOICE OF TOW VECHICLE IS THE M915 A HOLE LOT SMOOTHER TRUCK FOR TOWING AS FAR AS GOING INTO A SKID THATS MY FRIEND IS "DRIVER ERROR" AND MAYBE SOME DUMB 4 WHEELER DARTING THATS WHY WHEN TOWING EVEN WITH A TOW TRUCK WHICH I HAVE DRIVEN YOU NEVER AND I REPEAT NEVER GET IN A HURRY THATS WHEN BAD STUFF HAPPENS . 2cents2cents2centsaua
3dAngus
102
Perry, Ga.
Makes sense, but in the commercial world, at least in MIddle Georgia, I don't think I have ever seen a tow truck on open road NOT going well over the speed limit. Always in a big hurry, and it is wise to stay out of their way. Dangerous!
krall
shippensburg PA
yeah they can be dangerous, I am intrested in seeing how it goes towing a bigger truck behind,will definantly have to figure out how to make the 1" work, will have to get the big tow bar home and see what we can fabricate.
krall
shippensburg PA
well I am thinking it would be smart to do, how much you looking for it and do you get over towards my way often? I am close to mechanicsburg or really close to chambersburg where they sell stuff from DRMO in pa. how much does yours weigh?
emr
25
landing , new jersey
You really need a medium tow bar... I have ONE of those cool 1.5 to 1 inch , and can not wait to get another... :) I also have the humvve ends that fit the heavy tow bar it goes from 1.5 to 3/4 inch pin, sooooo this is the one to copy if someone wants to make some, alot less material than the pig ones shown that i also have one of,,, and will work just fine, sorry i can not find a pic, will try if i find this post again...
3dAngus
102
Perry, Ga.
emr, if you have a 1.5" to 1" adapter set for a towbar, I'm in the market.
R Racing
17
St. Leonard, MD
If you guys need a few sets of the 1.5 to 1" adapters let me know . They could be machined out of steel and be stronger than the cast 1s. Just would some measurements to draw up the program.
D
Deleted member 11142
Guest
im interested.
3dAngus
102
Perry, Ga.
Might even be better if you had the actual thing.
I have a friend that is going to mail me one for a template.
I will check with him to see if he would mind if I shipped it up as a loaner for you to take your own measurements. It would cut down on the errors. I'll send you a PM on this.
area52
San Bernardino CA
One thing to think about with the 1.5" to 1" adapters - not just reducing the inside diameter of the hole but checking on the "thiickness" of the feet so the holes line up. I am talking about the bottom part that sits on the bumper. I think on the larger feet, that area is bigger so the holes will not line up even with a reducer bushing in the hole.
Does that make sense? If its not too cold tomorrow, I will get one the large towbar feet and check to see if it lines up or not.
