Fuel Injector Cleaner
QuickSilver
Wyoming
Eye ball it. Most of the times there is a scale on the back of oz of additive to gallons of fuel. Most bottles have a clear strip and a scale on the side that show how many ounces are remaining in the bottle.
Ya, that's how I've been doing it, but on something the size of a jug of Power Service it's hard to be very precise when you need one ounce to every three gallons. I'll come up with something. :?
erniemigi
Amelia, ohio
The M1009s are the only one in the m1000 series to have a 27 gallon gas tank, the rest all have a 20 gallon, so for the M1009 it would be 9 ounces for 27 gallons, and 7 for the 20 gallons, or just a fuzz over 1 cup or fuzz under 1 cup depending on the size of gas tank
donalloy1
Martinez Ca
I have been using the Stanadyne Fuel Performance additive. Mostly because friend says way to go and I gather Stanadyne is manufacturer of ip. Does not seam to be helping me much. Will probably slow down frequency and go to ATF. I only get about 14-15mpg around town. About half highway and half city. Thought I would do better than that. Going to cross check odometer this week with gps.:confused:
jdemaris
What kind of injector cleaner do you guys think works best in our engines?
I don't believe any cleaner does a thing for the type of injector nozzles used in the 6.2s. They are pintle-type nozzles, i.e. no small mulitple nozzle holes to plug.
I've had many apart and have yet to ever find one that was suffering from anything but metal-parts wear. No cleaning fixes that.
Considering they often last 200K miles, and brand new nozzles only cost around $5 each, not much to worry about.
I use two-stroke-oil as a lube additive but that is jsut to help all close fitting metal parts last a little longer. Nothing to do wtih cleaning.
ssgtcampbell77
Staff Sergeant
227
St Louis MO
Where are you finding injectors for $5??? I havent found any for under $70.
thtrev2001
25
San Antonio, Tx
You learn something new everyday. After putting the BG fuel additive in the tank, our 6.2 ran alot smoother, not sure why but it did
mtn man
10
Wilkesboro, NC
Dieselclean- white bottle in winter and gray in the warmer months here in NC. Haven't had any issues on 2 CUCV's doing about 10k a year. As for measuring I was using the lid from a old clothes detergent bottle... I think it was 4oz. after awhile I got a feel for it and would just add by 'eyeball' when I topped off the tank. Get 16-18 on the trucks.
mr.travo
Comfort, TX
I use the 'ol "Guess-ta-mate" system for measuring. Has never let me down. I am a die hard Power Service guy, but am thinking about switching over to ATF for a few months to see if that's any better. Whats the ratio of ATF per gallon and what's the best/cheapest ATF to buy?
Josh
12
Portland, Oregon
If ya need 16 ounces of something, A snapple bottle works great. Thats what we used to put 2stroke oil into our boat. I dont know if the cucvs have check valves like gassers, but if they dont, it should work great.
ssgtcampbell77
Staff Sergeant
227
St Louis MO
ATF ratio
I usually run a quart of ATF per tank of fuel about every four or five fill ups.
Milkman357
15
Des Moines, IA
My project
Last summer I was running a 50% blend of ATF(used) and Diesel... it was too much. Clogged up the Fuel nozzles.. It ran pretty good on the stuff until nozzle problems developed. I had a spare HUMMVE engine in a can, so I swapped fuel nozzles...
This year my plan is not to ex-cede 20%... and use the Power Service in a Gray bottle..
Like others have done with other diesels... if you had two fuel tanks that would be the best system. Start on Diesel... switch over to Waste Oil.. then before shut down run on diesel again to flush the systems...
I'm not Hi Jacking here.. just saying.. I've heard good things about the Power Service.... and ATF will cause issues at 40 - 50% mix.
