ssgtcampbell77
Staff Sergeant
- 227
- 1
- 0
- St Louis MO
Most additives will say 1 qt to a tank of fuel. Most.
Ya, that's how I've been doing it, but on something the size of a jug of Power Service it's hard to be very precise when you need one ounce to every three gallons. I'll come up with something.Eye ball it. Most of the times there is a scale on the back of oz of additive to gallons of fuel. Most bottles have a clear strip and a scale on the side that show how many ounces are remaining in the bottle.
I don't believe any cleaner does a thing for the type of injector nozzles used in the 6.2s. They are pintle-type nozzles, i.e. no small mulitple nozzle holes to plug.What kind of injector cleaner do you guys think works best in our engines?
Where are you finding injectors for $5??? I havent found any for under $70.I don't believe any cleaner does a thing for the type of injector nozzles used in the 6.2s. They are pintle-type nozzles, i.e. no small mulitple nozzle holes to plug.
I've had many apart and have yet to ever find one that was suffering from anything but metal-parts wear. No cleaning fixes that.
Considering they often last 200K miles, and brand new nozzles only cost around $5 each, not much to worry about.
I use two-stroke-oil as a lube additive but that is jsut to help all close fitting metal parts last a little longer. Nothing to do wtih cleaning.
I usually run a quart of ATF per tank of fuel about every four or five fill ups.I use the 'ol "Guess-ta-mate" system for measuring. Has never let me down. I am a die hard Power Service guy, but am thinking about switching over to ATF for a few months to see if that's any better. Whats the ratio of ATF per gallon and what's the best/cheapest ATF to buy?
