rod
- 2
- 0
- Alabama - The Heart of Dixie
I'm just a few days out from changing my glowplugs in my '84 M1009 and have purchased a set of the AC Delco 60Gs to put in. I know that the spade on the 60G plugs are wider than the original ones and wil need to be ground down so the original clips will fit the spades.
As I was preparing to grind down the spades on the AC60Gs, I thought I would pull of a wire on the existing glowplugs to check to see if the glowplugs were the normal width spades or the wider spades (just incase someone had already changed out the ends.
What I found suprised me some because the glowplugs in the engine have a round tip. Here is a picture of one of the glowplugs. Can you help identify them and provided any known issues with changing them out which would make them easier, more difficults, etc......?
