- 65
- 18
- 8
- El Paso, Colorado
Whatever I need it to at the time.how much of that do you want to pull with your deuce?
But, I appreciate any advantage I can gain.
You are going to find that pulling a heavy trailer with a deuce is going to be a slow go.......the normal deuce multi-fuel is around 140 HP.....an LDS will bump it up to 180 or so. It will fall flat on it's face on a hill.
The deuce was made to pull heavy loads over rough terrain at low speeds.....it is never going to be a good over the road hauler for heavy loads.
Somehow, I think 'he'll' cope with a lack of speed this time.I hope he loves 2nd gearMy 350hp F450 pulls hard when I have a 26,000-28,000 lb trailer behind it.
you realize what the towed ratings of the deuce are, right?Whatever I need it to at the time. ...
I agree, but remember that rating is based on the pintle and not a goose-neck or fifth wheel configuration.try the data plate on the dash; likely it says something like max towed load is 6k# offroad and 10k# highway.
so w/ a 30k trailer being somewhere around 5-6k# empty, that leaves you with about 4k# of load to put on the trailer.
seems a bit excessive amount of trailer.
Travis I wasn't a proponent of the illegitimate GN in the first place.yeah, i knew someone would bring up pintle vs illegitimate GN.
good luck grossing 43k in a 130hp deuce.
Here's what I'm planning on doing when I get a gooseneck. Convert the trailer to pintle instead of convering the truck. The idea I had was to have the hitch pinned on at the back so it can be removed to tow with a regular truck. There's a thread around here somewhere with pics where somebody has already done this but I can't find it.
I think the Hay Train looks great. That is awsome ideal, it always amaze me to see the mods everyone comes up with. Now its time to design one for a 5th wheel.
This is an interesting concept.Here's what I'm planning on doing when I get a gooseneck. Convert the trailer to pintle instead of convering the truck. The idea I had was to have the hitch pinned on at the back so it can be removed to tow with a regular truck. There's a thread around here somewhere with pics where somebody has already done this but I can't find it.
Anyway, here is my attempt to draw out what I'm talking about. The black lines are the gooseneck trailer and the red lines are a fabbed up piece of tubing that has pins attaching it to the trailer at the back of the neck, a ball welded on it at the factory hitch, and a lunette added on the end.
An 18" lunette ring attached to the king pin would create some interesting clearance issues in the back of certain hauler boxes...This is an interesting concept.
I ponder the need to have the Lunette Ring (aka "pintle") removable from your trailer's gooseneck structure.
If the lunette ring was extended about 18" forward from the vertical post on the trailer, it should clear all obstacles on the back of the Deuce AND still be within acceptable limits on a typical pick-up's "swing clearance" forward of it's fifthwheel or ball.
There would be nothing removable, not risk of injury manhandling the "adapter bar", just the presence of both hitching options all the time.
Any thoughts????
I realize that specific tow vehicle clearances would have to be factored in. Yet I suppose that it could also be "used" as a theft deterentAn 18" lunette ring attached to the king pin would create some interesting clearance issues in the back of certain hauler boxes...
I was going to edit my response to add that you could just fab up an lunette insert as the actual hitch on the Gooseneck is adjustable, and replaceable. In fact I was looking through these catalogs at some of the optional inserts.I realize that specific tow vehicle clearances would have to be factored in. Yet I suppose that it could also be "used" as a theft deterent![]()
