I have been looking over websites and watching threads on here to get an idea on the first phase build for my new blazer. Do any of you see anything I dont need or should as to this setup? My credit card it screaming at me to be used ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
"From a M1008"
Front Axle: Dana 60
Rear Axle: 10.5" Corporate 14 Bolt Differential, with a Detroit Locker
www.trailworthyfab.com
(5) 8 Bolt Hummer Wheel Special w/
Goodyear Wrangler radials 37x12.50x16.5 - Hummer Tires $1650
www.diy4x.com
14BFF Guardsman $65
Razor Back 14 Diff cover $160
Razor Back 60 Diff Cover $155
www.offroaddesign.com/
1. Weld-in Frame Repair kit
GU39002 $80
2. Dana 60 Crossover Steering and High Steer Kits {$580}
Pitman arm
Part #:70203 $70
Steering arms:
RH Arm Part #: U9001
RH Arm Price: $150.00
LH Arm Part #: U9003
LH Arm Price: $150.00
Stud kit part #: U9002
Stud kit price: $30.00 (set of 4 ARP high strength, 190,000 psi studs)
Draglink:
Tube part #: U9015
Tube price: $95.00
Ends for draglink and tie rod #:U9016 $95 per pair
High Steer Tierod:
Tube part #: U9014-High Steer
Tube Price: $85.00
3. Lift System {$1097}
Front U-Bolts:
1/2t and 3/4t front ubolt kit TCI-17701 $30
Heavy Duty Greasable Front Shackles GU37011 $99
Greasable Spring Main Eye kit GU37012 $27
Brakelines:
79-98 and D60, 10mm Brake line kit through 6” Lift GU30011 $112
Sway Bar Disconnect Kit GU37001 $99
Swaybar bushings:
Sway Bar Bushings 81-87 BG05003 $19
Bolt-in steering box brace:
81-87 GU39001-L $130
Rear Shackle Flip kit:
½, and ¾ ton 4” Shackle Flip 73-87 GM GU38010 $189
Rear U-bolts:
½ ton Rear U-Bolt Kit TCI-17751 $36
Bilstein 5125 Shocks set of 4 $356
4 pcs BE5-A465-H7
"From a M1008"
Front Axle: Dana 60
www.diy4x.com
14BFF Guardsman $65
GU39002 $80
Pitman arm
Part #:70203 $70
Steering arms:
Draglink:
Tube part #: U9015
Tube price: $95.00
High Steer Tierod:
Tube Price: $85.00
Front U-Bolts:
Brakelines:
Swaybar bushings:
Rear U-bolts:
4 pcs BE5-A465-H7
