Reading parts for the upgrade
caladin
So Cal
I have been looking over websites and watching threads on here to get an idea on the first phase build for my new blazer. Do any of you see anything I dont need or should as to this setup? My credit card it screaming at me to be used :D
"From a M1008"
Front Axle: Dana 60
Rear Axle: 10.5" Corporate 14 Bolt Differential, with a Detroit Locker
www.trailworthyfab.com
(5) 8 Bolt Hummer Wheel Special w/
Goodyear Wrangler radials 37x12.50x16.5 - Hummer Tires $1650
www.diy4x.com
14BFF Guardsman $65
Razor Back 14 Diff cover $160
Razor Back 60 Diff Cover $155
www.offroaddesign.com/
1. Weld-in Frame Repair kit
GU39002 $80
2. Dana 60 Crossover Steering and High Steer Kits {$580}
Pitman arm
Part #:70203 $70
Steering arms:
RH Arm Part #: U9001
RH Arm Price: $150.00
LH Arm Part #: U9003
LH Arm Price: $150.00
Stud kit part #: U9002
Stud kit price: $30.00 (set of 4 ARP high strength, 190,000 psi studs)
Draglink:
Tube part #: U9015
Tube price: $95.00
Ends for draglink and tie rod #:U9016 $95 per pair
High Steer Tierod:
Tube part #: U9014-High Steer
Tube Price: $85.00
3. Lift System {$1097}
Front U-Bolts:
1/2t and 3/4t front ubolt kit TCI-17701 $30
Heavy Duty Greasable Front Shackles GU37011 $99
Greasable Spring Main Eye kit GU37012 $27
Brakelines:
79-98 and D60, 10mm Brake line kit through 6” Lift GU30011 $112
Sway Bar Disconnect Kit GU37001 $99
Swaybar bushings:
Sway Bar Bushings 81-87 BG05003 $19
Bolt-in steering box brace:
81-87 GU39001-L $130
Rear Shackle Flip kit:
½, and ¾ ton 4” Shackle Flip 73-87 GM GU38010 $189
Rear U-bolts:
½ ton Rear U-Bolt Kit TCI-17751 $36
Bilstein 5125 Shocks set of 4 $356
4 pcs BE5-A465-H7
Mohawk Dave
14
CA
Wheel spacers (2"iirc) or DRW hubs up front to clear the HMMWV rims, and make sure you use grade 8 and stover nuts on all the suspension. Do NOT use F9-11 hardware as it has more tensile strength, but is more likely to snap compared to grade 8.
Best wishes and post pics!
Dave
caladin
So Cal
I am planing on going Highsteer. Do you think the 3" lift will be enough to run those tires or do you think a 4" inch is needed? I dont want to cut my fenders if I dont need to?
86m1028
Murphy TEXAS
"From a M1008"
Front Axle: Dana 60
www.diy4x.com
14BFF Guardsman $65
GU39002 $80
Pitman arm
Part #:70203 $70
Steering arms:
Draglink:
Tube part #: U9015
Tube price: $95.00
High Steer Tierod:
Tube Price: $85.00
Front U-Bolts:
Brakelines:
Swaybar bushings:
Rear U-bolts:
4 pcs BE5-A465-H7
You do not need the sway bar disco's or bushings if your going crossover.
I wouldnt do the weld in box brace unless your frame is already damaged.
I had 6 inches of lift & my 35's rubbed. I think you will need more than 3in if you dont want to trim.
Frt u-bolt kit is wrong if going with a dana 60.
If you use a 14 bolt from a 1 ton you will have to move spring perches & shock mounts.
caladin
So Cal
By crossover do you mean crossover or highsteer. Im going highsteer if that makes a differances.
Why not go with the weld in brace for assurance?
How did the 6" lift ride?
caladin
So Cal
just got of the phone with ORD. This is what they recommend for 6" lift.
Dana 60 Crossover Steering and High Steer Kits {$800}
Pitman arm
Part #:70203 $70
Steering arms:
(2) Stud kit part #: U9002
Draglink:
Tube part #: U9015
Tube price: $95.00
(2) Ends for draglink and tie rod #:U9016 $95 per pair
High Steer Tierod:
Tube Price: $85.00
3. Lift System {$2011}
ORD Complete 4x4 Lift Systems & Kits - GM Chevy Leaf Springs
Front lift springs:
6” EZ-Ride Front Tuff Country Springs $350
Front U-Bolts:
1 Ton (Dana 60 Front Axle) U-Bolt Kit #GU37051 $48
Brakelines:
Swaybar bushings:
Rear Lift:
4” Shackle Flip '73-'87 ('91) GM #GU38010 $189
3" Rear Tuff Country Lift Spring $456
Greasable Suspension Components:
Greasable Rear Spring Bushing Kit 1 ½” Spring Eyes and 1 ½” Shackles #GU38002 $90
Rear U-bolts:
4 pcs BE5-A465-H7
caladin
So Cal
Just got off the phone with ORD. This is what they recommend for 6" lift and a Highsteer Front end.
Pitman arm
Part #:70203 $70
Steering arms:
Draglink:
Tube part #: U9015
Tube price: $95.00
High Steer Tierod:
Tube Price: $85.00
Front lift springs:
Front U-Bolts:
Brakelines:
Swaybar bushings:
Rear Lift:
Rear U-bolts:
4 pcs BE5-A465-H7
Brent.Cain
Canal Winchester, OHIO
Dana 60king pin front axles are nice but if your thinking of hard core off roaring I would buy another 14bolt ff and build a hybrid front axle with dana 60 front inner an outter C knuckles it will be 10x stronger cause the 14bolt has a pinion support unlike the 60 and they are finding out that the 60 pinion ends up. Pivoting up in down cause of how long they are:cookoo:
