LuckyDog
- 11
- 18
- Freedom, NH
There are actually four glow plugs on the MEP-002A (Six on an 003A). All are used. The two in the head are wired in parallel and are 24 volt units. The two in the intake are wired in series and are 12 volt civilian types.There are two glow plugs, I don't know if they are both used and if one is a spare that you can just switch the wire to the other one, I'm not sure.
That information is kind of discouraging to me.The dribble you hear returnig into the fuel tank is normal, and if it sounds like a dribble like (mine does) your good.
I thought the nut and allen were the adjustments for the pop-pressure of the injector?In regard to your stuck nuts soaking in PB, you can tell if you are getting high press fuel to the injectors by loosening the, I think 7/8, nut on the top of each injector or if you can take out the allen threaded plug in the top of the same nut I just mentioned.
Once you get either of these free put them back on but not wrench tight and turn over the engine. If you can be at two places at once, see if you get fuel at this point. It will tell you if your IP is putting out.
That is why I am trying to get the return line fitting off, so I can see if the injector has fuel coming out that orifice.
So, with the above sentence, I assume IF i loosen the cap with the allen, I had better be counting threads?... If you take appart the injectors you must count the threads on the allen holed cap which puts the right spring tension on the injector needle. ...
I don't think I want to mess with that setting.
That is my (and I think Joe's) problem.... but I guess the question is why it stops getting fuel? ...
