WARWAG
- 25
- 38
Thanks. I checked out your build thread again and saw where you cut them at. I can see now how they would hit since the rear shackles are not a Civi vehicle add on. It should not be a problem to notch them.
not to hight jack but this is somthing i have been woundering if i should have got them. i am going to run 37's on a 17x9 with 5 inches of B.S and was woundering if they would have worked better then just my 4 inch lift.are you putting zero rates up front ?
Im not sure what "Zero Rates" are. I am installing the HD Tuff Country 4" leaf packs if that helps answer your question.are you putting zero rates up front ?
