O.R.D. 4" Lift
WARWAG
Well its been snowing again here in Nevada. So I brought the leaf packs back in and installed the new greaseable bushings. The process of removing and installing the bushings would work for old worn out bushing being replaced with stock bushings as well. This WILL save you allot of times and headaches by following my process which I had to experiment arount to figure out the easiest and fastest way to remove and install.
When removing the old bushings I used two types of Channel Lock pliers. Flat edge and the V edge. The V edge is the absolute best and the only one to use on the smaller diameter bushings.
I simply grabbed ahold of the outer edge of the bushing with the V Channel Locks. You then rotate the bushing back and forth until you hear it start to squeak. Keep rocking or rotating the bushing back and forth while you also apply force away from the spring pack.
Once it comes out do the same on the other side.
Now that the Old bushing is out clean the inside of the spring eye with WD40 or whatever you have handy. Follow up with paper towels and now its clean.
Next get some good grease and take a good size gob and smear it on the inside of the spring eye. Cover all internal areas and both edges. Dont be shy like I was the first time. You need grease to make this work!
Next lube the new bushings outside and inside. There will be a metal tube that you should also lube the outside of on one side. The bushing is in two pieces so lube the one without the metal tube as well inside and out. DONT BE SHY ON THE GREASE LIKE I WAS! You need grease to make this work.
The side with the metal tube I tapped into the eyelet all the way first. It will need some force to get it in. Now take the other half and start to tap it in as far as it will go.
Now you will need a vise and a few large washers to push the bushing the rest of the way in.
Place one large washer (the hole should be slightly larger than the eye of the bushing) on each side of the bushing ends.
Now close the vise and it will slowly push the bushings in.
This is the simplest and easiest way to install the bushings. If the weather clears up I should have the kit installed by this weekend.
firstcucv
MN
lookin good. i was going to do a right up like this for my first post. but well i got in to it and forgot the pics. i used a hammer and a 2x4 to pound my new O.R.D bushings in they came with a littel film of somthing on them and they went right in. if you end up triming your fenders for your tires i would like to see pics and detall on that. i am wating for my wheels to show up then tires.
WARWAG
My bushings did not have any slick coating on them. I also used a 5 lbs sledge and 2x6 and was only able to get them in about 3/4 of the way and that was it. With the grease and vise I had the second one done in 30 seconds! The first set was all trial and error and allot of wasted time. The second set was a breeze!
firstcucv
MN
are you putting zero rates up front ?
not to hight jack but this is somthing i have been woundering if i should have got them. i am going to run 37's on a 17x9 with 5 inches of B.S and was woundering if they would have worked better then just my 4 inch lift.
Cucvnut
75
Carver, Oregon
well if you run them you can move the axle forward to help with tires hitting the wheel well. but you have to extend your front drive shaft.
Cucvnut
75
Carver, Oregon
Zero rates are a one inch thick add a leaf that allows you to move the axle forwards or backwards on the spring perchsprings. ORD sells them.
