Well, full disclosure... I didn't actually install this unit; it was already installed when the truck came to me.OK I have a question for you. The last picture that shows the on off and blower switches. Were does the white wire and the Black with the white strip thats marked control panel go to ?? I have several calls into red dot but so far no return call.
Thank you
Got it... I'll take more photos and measurements after work.thanks, here are the measurements i need in the photo.
also, what is behind the bracket on the driver side bracket of the condenser (have arrows pointing at the bracket)?
If I am not mistaken...it goes to the compressor and it's the clutch wire...OK I have a question for you. The last picture that shows the on off and blower switches. Were does the white wire and the Black with the white strip thats marked control panel go to ?? I have several calls into red dot but so far no return call.
Thank you
THANK YOU THANK YOU THANK YOU !!!!Well, full disclosure... I didn't actually install this unit; it was already installed when the truck came to me.
I went back in and tried to trace those two wires... the white wire seems to disappear somewhere behind the dash panel/firewall, but the blk/wht wire looks like it wraps itself behind the doghouse and connects to the compressor. Maybe the white wire is a ground?
yes and there is another set of wires that lead to a wire tap that taps into the power wire that goes to the std fan blower.If I am not mistaken...it goes to the compressor and it's the clutch wire...
sorry, here is the pdf file for the soft top...can't send the hardtop version pdf via steel soldiers-file is to big...VQ-1 I didn't seem to get the PM of the slant back instructions. Could you please try again when you have some time.
awesome, thanks a million!Here are the measurements... I'll post the photos of the underside tonight after work.
