jets1959
- 9
- 18
- Lakewood, WA
Thanks, I already checked three times visually and manually but will look again. What were you prying againest? I don't want to pry againest the valve covers. What valve was glogging?
Sorry this has been so long for an update. I used my engine hoist and had the front tires off the ground before it finally broke loose. All the bolts were out I don't know what they used on the gaskets but I sure could use some for other things that will be installed once and left on forever. Got it all back together and it runs great had to changethe vacuum pump out and now the trans. shifts like is suppose to. Thanks for your help.i think i just poped loose with a bar against the head!
