Price check - axle seal kit
emr
24
landing , new jersey
yea thats a good price I paid 12 bucks ea just for seals about 6 years ago, and am selling them for that now, plus 3 bucks for the paper :) and 5 bucks for the mettle thingy, and throw in the cork :)
Terexts
Winder, Ga
I paid $122.70 for 6 inner hub seals, 4 outer hub seals, 2 front axle shaft oil seals, and 6 axle flange gaskets. That was the best price I could find. I'm bout to do my front end and install the silicone boots when I get the time.
Terexts
Winder, Ga
I got everything from Erik's Military Surplus. I bought everything that I posted in my last post plus yellow silicone boots, everything shipped was $208. I shopped around before buying all that, I think that was a good price.
Ok just placed my order with Erick also. Payed $223. Front Axle Boot, Silicone *8376530S ***************2 **33.50 *Color = Green 8376530G
Rubber (no zipper) All
M35 Series 2.5 Ton
Trucks, 8376530G /
8376530S
Axle Gasket Set For M35 ***7521735 ****************2 **18.00
Series, 7521735
M35 Outer Hub Seal, 2.5 ***7061238 ****************2 ***8.75
Ton Series, 7061238 /
A1205Q667
M35 Inner Hub Seal, *******10896684 ***************2 ***8.95
10896684 / A1205Z650
Front Axle Shaft Oil Seal *7521789 ****************2 ***9.50
For M35 Series, 7521789 /
8738032
Front Axle Dust Boot ******7071100-7071099 ********2 **13.25
Clamps For M35, 7071100
and 7071099
Fuel Level Sending Unit ***MS500040-5 *************1 **40.00
For M35A2, MS500040-5
*******************************************Subtotal *223.90
DieselBob
13
Arnold Maryland
What's the scoop with the rear seals up front? Which one is it and why is it better? Thanks Jim
Although I haven't installed it yet it's been recommended to install the outer seal used on the rear spindle on the front to help seal the front bearings from dirt / water contamination. The logic would make sense because you end up sealing the bearing cavity on both sides just like the rear axles.
Mike929
22
DFW, Tx
Per the above diagram would gear oil have access to the ends of the axle tubes between the hub and axle or is that sealed at the differential?
davey8943
Columbus IN
mike929,
The answer is, it depends!
The front axles have a seal from the axle housing to the axle shaft, behind the knuckle. This keeps gear oil out out of the knuckle, king pins, boots, etc.
The rear axles do not have a seal from the axle housing to the axle shaft because there are no knuckles or king pins or boots, etc....
DieselBob has posted pictures of the rear axle configuration. So, yes, his picture shows gear oil access to the axle flange.
Make sense?
Dave
Mike929
22
DFW, Tx
mike929,
Make sense?
Dave
Yes. I could see where a solid axle attached to the hub of the stearing axle may cause some push in the corners. :)
Mike929
22
DFW, Tx
Just received the Green dust boots. ummm... they are lime green :(
Should I use them or cut my loses and buy another color?
davey8943
Columbus IN
Lime Green for me too...
They were the only ones the supplier had in stock, and my truck isn't quite show quality!
Call the seller, they may be willing take the lime green ones back and drop ship you some pretty red ones!
Dave
